Discuss Newbie after some advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ablister
Hi, firstly been on this forum a while and been lurking in the background looking through all the posts, has made some good reading! I'm a novice so can't help anyone hence my low post count.
Anyway...
basically needing to put a new radiator in the bathroom and wanting some advise on how to drain the water from the system. It's an ex council flat i live in which has a back boiler. Can't appear to find a drain valve for the boiler
here are some pictures of my setup if anyone can be kind enough to tell me what i need to do (call a plumber?!)
I have six radiators in the house, the manifold has 6 outlets, not sure if clear in this pic (mess was the leftovers from the council plumbers...). There are, i'm assuming, valves on the end of the manifolds, is this to carry out maintenance?
the boiler is above the pump/zone valves etc
Thanks in advance :)
Those valves on the ends of the manifolds look like drain off valves to me
I'd say they were isolation valves for the heating manifolds. Not seen them before, not really sure why you would need them tbh.
why dont you just isolate and drain down the rad that you want to replace. fit new rad and connect valves and bleed rad
Sometimes I have come across drain points poking through outside walls of a property. Not a good idea, I know.
Thanks for reply, that's what I'm wanting to do but don't know how. Think of me as a beginner but want to learn for future diy tasks
Sorry if you mean the valves in each side if the rad, one side won't close, it just spins round. Plus wanting to Install a thermostatic valve and it's a different shape of radiator and the valves are wrong angle
You probably want to get a plumber in if you live in a flat think of you neighbours. You could flood them out
Why not a good idea ? use to be my hallmark.
BTW the two isolation valves for the manifolds are plug cocks (just like the type you may find on gas system) wouldn't think you would be able to turn them off.
On the first picture the vertical 22mm pipe before the pump is that the vent?
I had a customer had one freeze and burst right in the middle of that cold snap winter 2010. No boiler, no heating, no hot water.
Well must be a lot colder winters "up north" cos my old nan's one went in 32 years ago & still hasn't caused any problems.
Reply to Newbie after some advice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or...
I am a newbie to this forum and need some advice please. My daughter has just bought her first house and naturally Dad has been asked to do some...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
