Discuss New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Means doubling the rad size if one runs with a dT of 10C.
What about legionella protection for DHW?, will all new boilers now have to have HW priority and increase the flow temp to 80C?.
You misunderstand Roy, the boiler will only be set to 55 deg C where the system has been designed for this, in which case there would be no advantage to turning the boiler up a bit.
In reality this will be all new builds and most complete system replacements, but it won’t be possible in all cases so there is no way manufacturers will restrict to 55 in the foreseeable future ……
Thanks but why are they stating a 55c flow? I usually set at around 65 if possible so should return at 54c so will condensate? Are they saying they want the full heat exchanger in condensating mode at all times?
Or is it more design your system to run at 55c flow temp. So can be swapped to a heat pump later? Heat pumps run at around 45-50c flow? Thanks
Boilers only start to condense at ~ 50/55C, see below.
Condensing boiler 55/35 dt is 25
Heat pump 47.5/42.5 dt is 25 that’s why so systems are heat pump ready
That would be good. Had a long discussion with a customer recently about what temperature she should set her boiler flow to and I mentioned that ideally, the boiler would do just that (but hers doesn't).
I've never managed to get a 25c delta T. Have struggled to get 15. We can't adjust the pump in the boiler. So just lockshield? I think Vokera mentioned on one of there boilers they had a pump were you could set the delta T.
Reply to New part L 55 degrees flow? in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
