Discuss New bath? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
con5933
Something I've found pretty useful when fitting a new bath.
We all know how difficult it can be to get the tools in behind the bath to connect the taps..
Now, it is easier with the flexible hoses i'll grant you that, but to make it even easier, make sure the tap nearest to the 'closed' or back side of the bath is connected with a push fit flexi. No more fighting while squeezed into a little gap:)
and remember...ALWAYS fit isolation valves..:D
Here is onei find works well
If you have to alter positions of existing pipe work when fitting a bath that has taps to the centre i put on the jg hand tight connectors then i use about 2 1/2ft of jg speedfit pipe with an iso valve on each pipe i find this method so much quicker than soldering loads of copper together plus it can be built up before you put the bath in place.
Hope this is of any use to anyone.
Matty
Just one thing to add don't buy the cheap pushfits off ebay, i know someone how did and out of 7 that he used he had 4 leaks, he has put the rest in the bin didn't work out so cheap
Matty
Nice 1 Matty, I do this too but the first time i forgot to secure them, 'slight case of water hammer' :) ended up stickin it to the side of the bath with sealant so it didn't jump every time the tap was turned off..:eek:
Never done a bath with taps 'in the centre' (and at the back I take it) yet. Not bothered about putting one in but I wouldn't like to be the plumber who has to tell a customer he has to rip the bath out to fix a faulty /leaking tap!
Its not as bad as you think to repair or replace the taps in the centre as long as the bath was not too big to start (plaster removed from both ends to make bath fit) if its a standard fit bath remove the pannel lower the legs and cut the silicone and uncouple the waste the bath will drop below the tiles and can be pulled out about 6'' you can then work from inside the bath and fix or replace the taps then refit bath as normal
Matty
I used this system when I installed the first of two bathrooms recently. Found it easier even after I'd spent an hour making templates and thought WTF use flexi's.
John
Mr
That's what I like about this forum.
Someone has a good time saving idea and shares it so we can all benefit. The idea of what are effectively extra long flexi tail pipes is so useful.
TH
Reply to New bath? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi Visited a customers property today to attend to a leak behind the bath on the fitting.Heres the scenario, roll top bath original taps fitted...
5K
  • Locked
Hi, I'm just in the process of having my house replumbed using a combi, and have a question on the final connection to the bath taps. Up until...
8K
wheeto
W
  • Locked
Hello! I'm hoping you guys can help with this one as its proving to be a real nightmare for me. I'm trying to change the waste pie...
8K
  • Locked
What do you use for undoing tap backnuts when they're recessed in shapes on the underside of baths and basins that make them difficult to get at...
1K
T
A
  • Locked
Hi, Just connected bath using flexi tap connectors(push fit). There are no leaks,however i noticed that the cold connection after turning on the...
10K
REDSAW
R
