pole rigger
Good morning experts, hope this isn't too taxing but here goes! Gravity fed domestic central heating powered by Grant outdoor boiler, Riello rdb1 burner. After 7 years system works as it should having been serviced anually.
Recently a squeak has developed which is quite high pitched and disappears two or three minutes after the boiler firing. It is not a continuous noise but occurs 2/3 times per second.
Have changed the oil pump coupling but this has made no difference, there was no contamination in the oil feed or pump itself. There was a very small ammount of brown staining in the old coupling and some resistance to turning on the pump shaft but I am not sure how much resistance there should be.
I suspect the pump but of course could be motor bearing.
What really puzzles me is why, if there is a bearing problem in the pump or motor, the 'squeak' isn't a continuous 'squeal'
Any advice would be appreciated.
