Discuss looking for behind the wall shower valves with only the tap being exposed in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Deleted member 67158
Are there any dual lever shower taps/regulators, which I can install behind my shower wall ... the distance i need to bridge is 12 cm... ?
thanks for all your help. i opted for the spindle extension... as per your other posts.
that way i only had to drill a 7mm hole ( spindle ).
Reply to looking for behind the wall shower valves with only the tap being exposed in shower in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left. The...
Hi All Just looking for some advice on which Exposed Thermostatic Mixer Shower (Bar Shower) would go well with the Shower Pump i'm getting...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
