Discuss Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've got some, never used it though. You have to rough up the threads with your pump pliers first according to the instructions, never fancied doing that.
Never heard that one, never had a problem myself. (Not saying your wrong mind).
I think it says you should rough up the thread but I never have and haven't had any problems. Its good stuff.
I had a rad tail extension a couple of weeks ago that was an absolute bugger to seal, I considered the loctite, but ended up with 22 (yes 22!) wraps of PTFE, I went up in 5s from my usual 12 wraps until it held.
I think the thread roughing is to hold the loctite and stop it sliding out as you tighten the fitting. Will have a looksee at the loctite site, I'm sure there's a video.
Here's the video [video]http://www.loctite.co.uk/loctite-4087.htm?nodeid=8802627059713&msdsLanguage=EN_GB&selectedTab=video[/video]
22 I usually put 18 on as standard and I had one batch of cheap reads & valves that all leaked until I put between 36 & 45 wraps, used about 10 rolls of ptfe on that job
I used this for the first time yesterday on a compression that wouldn't seal.
Spot on
Excellent
Do you mean a male or female iron rocket and your putting the 55 on screwed fittings, if its just a compression fitting i wouldnt be putting loctite 55 on anything.
My starting point is normally 18-20 wraps aswell if i ever use PTFE
I find one wrap / gas ptfe is much better
Locktite 55 is good, I rough up bigger threads with a hacksaw blade
I used to carefully place the 55 cord in the threads not wrap it like a birds nest as shown in that video.
Used loads of 55, never roughed up the thread and never had a problem.
Mind you I use it exclusively on LCS not rad tails ect
Any of you used the liquid stuff I nearly passed out when they told me how much it was ! Never brought it.
577 plumb ? If so its good very good
It is expensive. But very good for difficult jobs when you need yo line a fitting up.
I use it for making valves onto chrome towel rails. Put a small amount on the start of the thread and screw in hand tight. Leave for a couple of hours and that's it! I tend to do them the day before. So far no problems.
Shaun beat me to it Loctite 577 on everything threaded I have used it since they made it is very good also better than the previous 572
I didn't have a choice. I just wouldn't seal. It was either loctite or ptfe or an adjustable through the window!
I would argue (not me normaly) Loctite 577 is faultless
Never have a couple of hours to wait so tape or cord for me then.
I'm fascinated by how good this 577 stuff is but as rpm just said I can't really think of a use for it. I use PTFE on everything and have no issues. If something leaks with ptfe it needs redoing not trying something else.
No don't do with pump pliers ... You will need a normal hacksaw blade and scratch the thread so the it gets rough to get a better hold.
Loctite is best stuff , you do not need much and it seals perfectly
You can use it for anything no everything it's good for steel and brass threads ... Good for gas pipes
Reply to Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
To repack a stop tap gland with loctite 55. Are you best having the stop tap open before you back the gland off to repack? I have always done it...
Deleted member 120897
Got some quotes for a service, one person has said if I haven't had the burner seal replaced for past 5 years, it should be done (& service price...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
Fitted a towel radiator today, I ptfe taped the radiator tails, and after installation noticed the tails were leaking a tiny amount. So de-fitted...
4K
I have a Victoria Plumbing concealed valve with 3/4" and 1/2" female inlets/outlets. I need to connect male iron 90 degree elbows (with...
2K
