Discuss Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plum Bob 66
Morning chaps, there was a thread on the forum a few weeks about jointing compound that went due south for some reason. In that thread I asked about the correct way to use Loctite 55 as I wanted to convert from ptfe. Nothing was forthcoming.
Would some kind sole be be good enough to give me a quick heads up of the best way to use and in what sort of quantities to get a good seal on rad tails etc, etc ?
Thanks Bob
On the tub it tells you how many wraps for 1/2", 3/4" etc etc only used it on commercial but never on domestic but that said, its good, although expensive
Yes I saw that, I have the little 50 metre dental floss type dispenser. It just seems such a little amount to use to get a seal, compared to ptfe ,guess I'm going to have to take the plunge.
i replaced my outside tap and used 55 instead of ptfe, probably about a dozen wraps round the thread and it works a treat. no leaks with mains pressure.
A bit messy compared to ptfe for rad tails I find.
I once cross threaded a rad tail on designer rad tho, no amount of ptfe would seal it! Loctite 55 cord saved my arse that day, and had earnt its place in the tool box...
if you use to much loctite thread it will bunch up and look messy and cost!
It's a really good bit of kit I never use PTFE anymore, when it does bunch up I just get the blow torch out a few quick blasts and a wipe and its as good as new.
I wrap it the amount as stated on the container and it works. Wrap it any old way and it will seal.
i try to get a even coverage as said it does look a bit messy if it bunches out a bit, float your blowtorch over it and it burns straight off.
Loctite 55 all the time for me. It does 'nt clog your tool box up like a broken reel of ptfe. I still prefer boss white and hemp on barrel as the loctite binds the thread up.
Beauty is that you can back it off a little and it generally wont leak. Very important when you need to get fittings looking aesthetically right.
Yet to try this but why do they tell you to roughen up the thread with a pair of grips first?
i dont think its exspensive the number of half rolls of ptfe i used to throw away it always amazed me how a roll of ptfe left unchecked could attach its self to every tool in the box
To give a key for the individual strands to sit across the thread without slipping off.
Reply to Loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have installed my concealed shower valve and fitted wall panels, I'm soon ready to put shower fittings through the panels and screw them into...
2K
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised...
