Discuss Leak under kitchen sink in the USA area at PlumbersForums.net
Hi. I was
Wondering if anyone can help
I had a huge leak under my kitchen sink
And where the bowl sink kit goes onto the outside pipe/waste I just can’t get a seal, just doesn’t stay on.
Can see in video/pictures
Can anyone advice how I sort this out.
It’s almost like all of a sudden just doesn’t go on far enough to actually do anything. When pushed in it only
Goes as far as the picture with the black mark on
  • IMG_7797.MOV
    11.6 MB
  • IMG_7798.MOV
    4.4 MB
  • IMG_7792.MOV
    13.4 MB
The part your trying to push on remove the nut on the end should unscrew and you will notice a black rubber washer in the elbow you need to fish this out
On the pipe goes nut, washer, rubber cone washer cone towards the elbow then the elbow tighten and you should be good
You have a rubber seal missing , it should have a chamfer on one of its sides , are you sure its not there
There is a rubber seal on the actually pipe just where it’s screwed on to the waste pipe. But as you can see on video hopefully. It just doesn’t tighten. Just is loose and doesn’t provide a seal.
I can only see one vid for some reason , as you look at the picture you have just sent , the seal is to the right on the elbow , not on thin round one on the left
There is defo not this top on either part. The part trying to fix in has a small black seal inside like one on the link small one but nothing on the actual waste pipe
So the big top rubber one you mentioned should be on the waste pipe (middle picture) before I attack the elbow ? Then that should provide the seal tight ?
any idea size would need ?
Any idea what size might need shauncorbs?
Reply to Leak under kitchen sink in the USA area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a...
Morning, Moved house a few months ago and first issue is having a slight leak on tap in kitchen. Went under sink to turn off water and there are...
Deleted member 120897
My mother has been away on holiday for a few weeks and she has a kitchen mixer tap that has a very slow drip nothing significant - been like that...
For over a week the kitchen sink is leaking water from what I think is called tundish ( I thought is was called overflow but little google search...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and...
