R
realstokebloke
If your existing pipe off the top of the cylinder runs horizontally straight from the top of the cylinder then a Warix flange is easiest. The top outlet is connected to a dip tube to avoid air entrapment.
The thread on the top of your cylinder will probably be 1" FI but could be 3/4.
Yes, it has an elbow out of the top & then runs horizontally across.
So the Warrix needed is either 1" / 22mm (most likely) or 3/4" / 22mm then?
Is the " (inch) measurement across the fitting to check plse?
