Discuss Into wanted, outdoor sensor fitting on VIESSMANN 100 30KW B1KC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm fitting an outdoor sensor on my VIESSMANN 100 30KW B1KC. The wiring is finished, just need to know can I fit the wires any way around or is there a specific way to the 3 and 4 terminals connected to the sensor.
Anyone know?
Cheers
Doesn't matter
Reply to Into wanted, outdoor sensor fitting on VIESSMANN 100 30KW B1KC in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
I have an ideal vogue max S18 boiler and Iā€™m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler pump menu for either 70% or 100%, so, is the pump set at either one of two fixed speed percentages or does the pump actually vary speed, (modulate)...
