Discuss Installing hive thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good evening guys. I need some help fitting my new hive thermostat. First of all, I understood the hive thermostat requires at least 3 wires. I opened my old thermostat and I tried to see which cable is it but I couldn't understand. Can you help me with this?
Please find the picture attached. Thanks a lot!
You can't fit the hive there as it needs a permanent live, the transmitter is usually fitted near the boiler, using a permanent live from the fused spur. You could connect the existing switched live near the boiler and use that as your call for central heating. This would disconnect the wiring to your existing thermostat seen in the picture, you would then remove this and fit the battery operated hive receiver over the existing hole.
So what kind of cable do I need? Can you share a link from where to buy? Like screfix, wicks, etc. Thanks a lot.
Please don't take this the wrong way but if you are asking this I don't think you should be touching it ..........best you consult either a heating engineer, or a spark who does central heating systems ..........
So you have had help. But had no help?:D:D Just messing with you. I think that you should really get a heating engineer out.
Please don't take this the wrong way but if you are asking this I don't think you should be touching it ....best you consult either a heating engineer, or a spark who does central heating systems .
As I also stated above. I agree.
Reply to Installing hive thermostat in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I did all the wiring following the diagram in the attached picture. The boiler doesn't work anymore. Please, any suggestions?
Hi all. So I have just moved into a new house with a Potterton boiler in it. Great big thing!! lol. I want to fit a Hive to it but it obviously doesn't have a separate standard control box to just switch over like my last one owing to the internal timer etc. Inside the main unit is the...
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
I'm replacing my multi-zone Danfoss controllers with Hive, so far the downstairs Hive receiver is wired in and working well. I'm having a problem wiring in the Hive Single Channel receiver to replace a Danfoss TP 4000 for the upstairs zone. The TP 4000 is battery powered and has 2 connected...
