Discuss Insinkerator 3n1 hot/cold tap handle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
murdoco
HI,
We have had a insinkerator 3n1 fitted and when pushing the hot part of the hot cold side to hot it is touching the window sill so not getting fully hot.
Has anyone ever taken the end off to turn it forwards slightly? or offer any advice
Many Thanks
Simon
Not familiar with tap tbh. I would expect the tap has a cartridge and the spindle would likely be a square shape and in that case you can't just rotate it a little bit. You would have to rotate tap head 90 degrees from the vertical position to the horizontal position. Apart from looking a bit daft it may prevent you from then turning cold tap on fully.
Might make it easier to understand...
Cartridge with square spindle. No slight adjustment possible
Standard tap spindle. Lots of notches on spindle so slight adjustment possible.
Almost guarantee you will have the cartridge type in your tap
Send a PM to tomplumb83 he know`s all about these little babies.
Reply to Insinkerator 3n1 hot/cold tap handle in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
Hi I've seen a previous thread that is closed now regarding this subject but the end result I could not see. Our Shower runs hot for 30 seconds...
Can anyone help me with an ongoing issue I've had since I had an annual service on my combi boiler, which is a Potterton Performa 24. Literally...
Hello all, first time poster so if there is any additional information I can provide that may help, please let me know. Our kitchen mixer tap has...
