Discuss Identity help . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
Can any of you folks identify the cylinder/immersion heater in the pics please there no manufacture on the cylinder at all
Okay. Then basically any immersion element of the correct length with the correct boss size (looks like 1.5inch) will do.
Just make sure it has NO copper bits like pockets as they corrode much faster than the incalloy parts.
One should NOT use std immersions on a stainless cylinder.
HTH ;)
I was going to recommend contacting The Electric Water Heating company at Harlow I think they only do Internet now they used to have a store in East Ham E13 and were always a great source of info ....glad you got it sorted......regards Turnpin:)
Reply to Identity help . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've recently replaced an immersion heater for a direct cylinder, for 2.75-3kW. The new one seemed to be working a week before I got a callback. I checked the resistance of the immersion heater, and it read 19ohms, and the voltage on the live and neutral read 230V, but there was no humming or...
After some advice, i have recently had solar panels fitted and have an Eddi which uses the energy we generate to heat the cylinder using the immersion heater. Just wondering if there are any devices that can circulate the hot water in the cylinder so the immersion heater heats all the water...
Hi all, can anyone identify this flush valve, there are no manufacturers marks on it, the seal needs replacing, thanks.
I have read of hot water cylinders being heated with a dual element immersion heater. The main principle being that a shorter element heats the top of the tank and then, subsequently, a longer element comes into play. With a bath/sink switch the longer element may be disabled. The topic of such...
