Discuss Ideal classic ff240 no central heating hot water ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tartanarmyman
Hello folks looking for some help here my brothers house an open vented system . Ideal classic ff240does not fire up
When heating is switched on. Boiler only fires up when hot water is switched on. Checked power to boiler also pump rums when heating switched on but still does not fire up. Anyone
Got anything else I can check. Also checked room stat even linked wires wire for live to call wire together and still nothing
I am gas safe registered also
port valve and room stat
Tried linking the live wire and call wire that goes to the room stat but still nothing. Can't find the bloody motorised valve it aint in cupboard where cylinder and pumps are located. Pipes dissapear underfloor through wall
guess you got to go hunting
is there one on the hot water? its not a 3 port valve is it?
Nope not any valves in sight only two pumps one comes on when hot water is switched on and other pump comes on when central switched on but boiler only fires up for hot water only.
right ok
whats in the wiring centre ? (wiring wise)
In cupboard there is a electrical connector strip with am sure 4 grey power cables coming from wall into connector strip then the two pumps are wired in separately also the cylinder stat f
sounds like the prog is controlling the boiler and pumps, so could be a problem with the heating side of that
but system could do with updating
Also forgot to say opened the centre screw on pump for central heating when it was running but never seen any water coming out is that because motorised could be stick on hot water?
there might not be one depending on system (very old)
Or could it be a blockage on central heating pipework would that stop boiler firing up
When switching hot water on the boiler PCB has orange lights and turn on them boiler fires. But when central heating switched on nothing no orange lights.
When you say you have 2 pumps are they joined together ? maybe blue in colour ? has boiler got built in timer ?
Sorry should have updated my problem . Only one pump for central heating other pump is for heating water in cylinder after investigating. If programmer was faulty surely it would not switch on pump for central heating?
If it has 2 pumps there will be a relay somewhere.
That is the problem. There won't be any motorised valves
When he mentioned 2 pumps and no M/valves thought he might have had the old SMC twin pump system.
Yes two pumps in cupboard one comes on for hot water selected other comes on for heating selected. Only one header tank in loft space. Just noticed no water coming out heating pump centre screw maybe blockage possibly would that stop boiler firing up???
Not familiar with that boiler control but I did get called out to a Ferroli that had been put in summer mode by accident, took me hours to get there in traffic and saw the sunny symbol on boiler display in 3.5mS lol, otherwise I would hot wire the call for heat on CH directly on boiler and if no fire get onto manufacturer for their least expensive suggestion of parts to replace.,.., lol
This is a very basic boiler poss 20 + years old, if its fireing for hot water then nothing wrong with boiler, Hopefully OP will put up some photos of his controls & these 2 Pumps ?
Reply to Ideal classic ff240 no central heating hot water ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
losing pressure
L
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
