Discuss Ideal classic ff240 no central heating hot water ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tartanarmyman
Hello folks looking for some help here my brothers house an open vented system . Ideal classic ff240does not fire up
When heating is switched on. Boiler only fires up when hot water is switched on. Checked power to boiler also pump rums when heating switched on but still does not fire up. Anyone
Got anything else I can check. Also checked room stat even linked wires wire for live to call wire together and still nothing
I am gas safe registered also
port valve and room stat
Tried linking the live wire and call wire that goes to the room stat but still nothing. Can't find the bloody motorised valve it aint in cupboard where cylinder and pumps are located. Pipes dissapear underfloor through wall
guess you got to go hunting
is there one on the hot water? its not a 3 port valve is it?
Nope not any valves in sight only two pumps one comes on when hot water is switched on and other pump comes on when central switched on but boiler only fires up for hot water only.
right ok
whats in the wiring centre ? (wiring wise)
In cupboard there is a electrical connector strip with am sure 4 grey power cables coming from wall into connector strip then the two pumps are wired in separately also the cylinder stat f
sounds like the prog is controlling the boiler and pumps, so could be a problem with the heating side of that
but system could do with updating
Also forgot to say opened the centre screw on pump for central heating when it was running but never seen any water coming out is that because motorised could be stick on hot water?
Reply to Ideal classic ff240 no central heating hot water ok in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
losing pressure
L
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
