L
LaMont5way
Only in America. Why on earth would you feed the solder from the bottom.
Discuss How to solder vertical joints in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yeah I spotted that. Flux must have bound the pipe in the fitting till it got hot. Powerflow flux grips pipe something awful sometimes almost to the point of not being able to assemble the joint. Never had it happen with laco,but I prefer how Powerflow makes the solder run.I like how the pipe wasn't even pushed into fitting fully and then it drops in as he starts heating it lol.
2:09 incase you missed it
I think he must have been trying to make a point or illustrate capillary action at work by feeding from the bottom, either that or hes a moron. With most of these you tube vids you would think filming was really expensive as no one seems to re shoot there vids if they poop it. If you watched that vid back surely you would think "well that was kak better do it again" have to assume he thought it was great or didnt watch it after shooting it.
I don't have a guide. If you have 5-6 joints to solder at once then how would you measure that? Just do it by feel and eye.What do you guys use as a guide to say you've used enough sodder per joint...when you visibly see that the solder has capillary'd around the whole fitting or amount of solder? I tried using diameter of fitting as a guide for a while but found it was too much...15mm of solder for a 15mm fitting etc.
You could put kinks in the solder, each kink approximate to the length/amount you want to use.
Reply to How to solder vertical joints in the Plumbing Jobs | The Job-board area at PlumbersForums.net
