Discuss Hidden stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Kewat66
Hi All,
I have a request from a client to move a stopcock from its current position into a small loft directly above where it currently is. They want to plaster over the wall and put a radiator directly over it. My question is even though the stopcock is in a new position am i ok to put some form of lead lock over the current pipe/stopcock and get this plastered over or because i would be using a compression fitting do i have to allow access to this area? Also what is the best fitting for this requirement.
thanks
kewat66
You dont have too much choice but use a leadlock really.
instead of plastering it in could you not leave a small access panel in the plaster?
Can you not take the lead back to somewhere atleast accessible?
Or at least not going to be plastered in.
Into the floor maybe?
I prefer a Philmac fitting than a leadlock fitting :S Those go in the ground and dont need access etc
All you can do is advise the customer to leave access, up to them if they still want to plaster it afterwards.
i wouldnt worry if they decide to plaster over it its then their problem once there on and tested ive not had much trouble with lead locks just make sure its clipped in place well
Reply to Hidden stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
What’s the correct way to replace a (jammed and leaking) stop-cock in an old and corroded ½ steel pipe without damaging the pipe? The pipe in...
Hi everyone, Finally I have figured out what the two stop cocks in the kitchen do as they both had to be replaced due to leaks. The one under...
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
5K
