Discuss help gas cooker connection issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
HI is this self sealing end. Thanks
Good evening Keeley. One is and one is not. You will need a gas engineer to fit the new hose. Hope this helps.
neither are
also requires a gas safe engy as above
IS the end with
The elbow connection is what has been disconnected just wanted to know if it's self sealing until new cooker is installed by engineers.
Do you mean the bit attached to the gas pipe in the kitchen and not the hose?
T
The hose I have posted it was is attched to my cooker, it just pulled and twisted out of the wall. Tomorrow I have a gas safe person coming to install a new cooker however I wanted to make sure that's it's a self sealing pipe so it's no time leaking gas until the man turns up in morning. The end with the elbow was what was attached to the wall. Is this end self sealing
T
Only when the hose and the fitting attached to the gas pipe are together can you take a pic of the hose now and the pipe it attaches to?
You really should of left it for your gas safe engy to disconnect it
It should be ok but I've had a few that have leaked can you re connect it back up to the cooker ?
That’s is what I am thinking mate. But wanted to see as much as I could first.
No tape won't do anything best turn your gas off for tonight
The hose is attched to the cooker. The wall attachment is very close to wall to take picture. The cooker has been skipped as was broke.
If I put gorilla tape over end until morning would this help.
If I put gorilla tape over end until morning would this help.[/QUOTE]
As I cannot see what you have I cannot really comment any further. As shaun has said previously Most of the time they seal perfectly well but I have had them leak before. The only thing I can suggest if you are not sure is turn this lever off next to your gas meter. But then it will turn the gas off to the whole house
C'mon chaps. Whythe dramatics?
You all know that the cooker hose is designed for ANYONE to disconnect, and even that leaving the valve uncapped permanently is allowed. The act if disconnection is this sense is NOT classed as "gaswork".
That said, it is always possible that any valve can pass, and the outlet shoud be checked with LDF. (in practice no DIYer will have proper LDF and will turn to Fairly Liquid. Obviously a non compliant product, but has been used for decades, even as a heating silencer) Turning of the gas at the meter is not a bad idea, assuming no one dies of freezing overnight.
Assuming the meter valve does not pass. :)
It only takes a minute leak to give a smell, so I would only turn off the gas if smell is noticed.
Reply to help gas cooker connection issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I’m having a gas cooker pipe capped off. The GS registered plumber/ fitter, has told me that to do this, he’ll also have to service the combi boiler and check the radiators. (combi boiler was serviced in January by the original installer) Before retiring I was a joiner and honestly in the...
Hello I’d like to replace gas cooker. Curry’s do install but I know they will refuse to install if regs are not met. So I want to understand whether the proposed location is acceptable to qualified gas safe fitter. I can’t find official, definitive list of regs anywhere. Can you point me to...
B
I'm looking for a recirculating cooker hood as I have a flat and the cooker isn't near the external wall. Most of the cookers have carbon filters. Is that the same as charcoal filters ? Thanks
Hi, my mother had an electric cooker installed yesterday. The guy who fitted it said it shouldn't be close to the gas pipe but it is. The red arrow shows the gas pipes, the blue arrows are the electric supply for the cooker and the purple is the back of the cooker. I know nothing of plumbing...
Hey guys, I'm new to the forum but it looks great so far. I have a question about classifying a cooker .... Is a cooker with missing knobs AR or ID? I can work the hobs using the metal parts so they do work, but the plastic control knobs are mostly missing. Any ideas? thanks
