Discuss Fluorescin Dye in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Has anyone ever used fluorescent dye and UV torch to trace leaks in heating systems?
Any good?
Any reviews...?
What do you guys do if leak sealer doesn't work and there are no visible leaks from boiler of rads/valves..?
pipes in floor?
and thermal would be the best have a look at the flir one
This is mine, FLIR one I think, attaches to iPhone.
Pictures are leak from pipes in concrete floor.
Hot pipework is clearly defined where leakage occupies a larger area,
The copper was bleeding through, no hole just like a sponge.
Looks great.
However, I'm a little confused by the thermal image.
So I can see the pipe, clearly, which then disappears under the mass of heat which I would have thought was just heat from the pipe.
How did you know it was leaking there? (I know I'm being thick, sorry!)
There is somewhere a picture just outside the room, which shows the pipe again,from then on it was educated guesswork, luckily it was right.
So basically if that pipe wasn't leaking, there wouldn't have been that heat mass around the pipe like that?
there would have as not insulated and dont think it was leaking the way he said it also you will see the ground around a leak heating up i think
Reply to Fluorescin Dye in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello My solar thermal system appears to be leaking fluid (pics attached). Could anyone give me an indication of what the issue is likely to be...
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
I have a Worcester Greenstar gas boiler circa 2017. There has been a noise coming from the boiler which resembles running water, I have checked...
