Discuss Fitting shower alongside basin - width question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Atholl
Hi - My bathroom, plaster to plaster is 143cm. I would like to install a 900x900 shower and 500mm washbasin, leaving only 3cm! Is this enough for tiling, or I am trying to cram in too much? 800x800 shower is pretty small, as is 450 basin. Thought maybe a little of the 900x900 would go into the plaster, leaving maybe 4cm.
Any advice welcomed!
It should fit ok,your shower try is 900 wide the screen around it sits on tray so you will have at least another 10mm giving 20 to 25mm each side of basin ,this is enough,you may think about a moden square basin 500mm wide that can fit tight against the wall giving a nice space of 40 to 50mm between basin and shower screen ,wall side of basin could be recessed in wall if required to give slightly more space,or just leave central
Difficult to say exactly how much room the thickness of tiles will be as depends on wall level but should still be Ok
10mm tile depth x 2 = 20mm,
shower frame = 20mm,
equalls 40mm with a nats todger between the two if your lucky?.
i think, depending on the shower frame type ie, the adjustability of the end panel, say 40mm, then it may be possible with a large 'shelf' showing on the outer of the tray.
first thing i would do tho' is to fit the shower enclosure as narrow as possible then select a basin to suit.
good luck.
er! changed my mind, thats a 900mm shower tray isn't it?. so when the screen goes on it will leave at least another 30mm clearance. sorted. may look a little cramped though. not all manufacturers '900' trays are the same size.
Do the shower first and then see what room you have left.
How about a 400mm washbasin?
What about a smaller cubicle -800 x 800?
What about a small corner basin?
Reply to Fitting shower alongside basin - width question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
  • Locked
Hi Folks, Finally bought the house and get the keys on the 12th November! My job is as follows Complete install of bathroom, I haven't bought...
ManchesterGas
M
  • Locked
Hoping you guys can offer me some pointers and answers. I have done many of the individual bits of bathrooms a good few times, some only rarely...
3K
kay-jay
K
  • Locked
I'm refitting a bathroom and the client wants the shower on the opposite wall. I want to hide the pipes behind the tiling, but the plaster/render...
12K
smudger
  • Locked
I have been doing constant bathrooms this year, I keep saying "this is definalty the last one I do this year" but I've just taken on two more. I...
7K
E
  • Locked
Thought I'd start a new thread for how to fit out my upstairs bathroom. It's at studwork stage with most of the first fix pipework there...
9K
cc-sanitary
C
