Discuss Direct hot water cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When fitting a vented direct hot water cylinder, does it matter which side the cold feed goes into as long as it is one of the bottom connections?
If you mean the flow from the cwsc then it should connect to the bottom of the cylinder, to create push for the hot water draw off at top, the other holes will be direct flow and return to and from boiler.
There’s a connection for secondary return halfway up the cylinder which I blanked then 2 at the bottom, the cylinder is taking a long time to fill which is why I’m wondering if it can be done wrong
Possible can’t work out multiple entries to the cylinder though. Maybe a picture
Is this existing or recently installed?
Is there a gate valve anywhere on the feed from the tank?
Where is the Storage tank,, height relative to cylinder?
Is the vent vertical to storage tank or any horizontal runs?
Same with cold feed to cylinder, what's the run from the storage tank like?
It’s a replacement just installed. The gate valve is opening fully. The storage is in the attic but there is about a 3 metre horizontal run before it drops down to the cylinder. The vent goes straight up through the roof
Reply to Direct hot water cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a vented hot-water cylinder that was installed when the house was built - 38 years ago! It has a header tank in the loft and the cylinder is located directly above the ceiling of a new and expensive kitchen. It does not leak and causes no obvious problems. Should it be replaced? Advice...
Hi There was no shut off valve on the tank feed to the hot water cylinder, and I needed to move a couple of hot water pipes, so I shut off the mains water, turned boiler off (Remeha avanta) and opened the hot kitchen tap to drain the cylinder. After doing the work etc, Everything up and...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
Hi all. This ‘valve’ is at the bottom of our domestic hot water cylinder. Anyone have any idea what it is please? It must’ve been there for many years and seems to be leaking.
