Discuss Copper tap tails for monobloc in the USA area at PlumbersForums.net
Plumb Tidy
Hi lads just a quick one, can you fit isolation valves straight onto monobloc copper tap tails. I know they are soft copper i have always soldered onto them and never used compression fittings but on this job i need to fit valves on. I may even go as far as chucking push fit iso valves if need be.
Cheers.
Ben.
Yes you can no problem
Reply to Copper tap tails for monobloc in the USA area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
