Discuss Commercial tools? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
macka09
Hi guys.
I normally only work on domestic stuff so all my tools are obviously geared to that.
My question is what sort of tools do you guys use for working with 54mm compression fittings? And copper threads?
Thanks.
Don't normally use compression on 54 mm but Stilsons 24-36" anything bigger compression wise is different and has bolts instead of one nut (like a flange)
but it press or soldered normally
But most is like domestic but bigger
You can hire threading machines from bss etc have a look on the rems site
Sorry mate.
What I meant was. On a domestic valve you'd just use your adjustable and grips. Where's as the ISO valves I'll be using on site are used with a male copper thread both sides.
. As there 54mm would you still use stilsons on the copper? Just worried they may round them off a bit.
Yes it's just domestics.
hot and cold? if so non as boss white isnt allowed on hot and cold pipework due to not wras approved and water board are taking a big stance on it this year
Hmm. I'll have to check what paste we're using on the job just to be sure, but yes it is hot and cold.
boss green is ok for hot and cold (wras approved)
Is the copper thread liable to cross if tightened to much? I'm just thinking that copper is quite soft
as above your more likely to snap the fitting
If in doubt about cross threading, unwind the connection until you hear a click then start to tighten again. Damaged to fittings can occur if the male bottoms out and you continue to over tighten.
did you find out what boss you were using mucca?
Yes mate. There's a couple on site. Theirs boss green and jet blue.
I have a bad habit of calling most joint compounds boss white for some reason.
there fine boss green is ****
Any recommendations for wide jaw adjustables? Like 42mm and above
42mm wide or for 42mm comp fittings?
and stilsons if your on about 42mm fittings
Reply to Commercial tools? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
