Hi Guys,
Been having a real saga and head scratching situation.
I originally had 1 problem, and now 2.
Original issue: Air being built up in rads. Having to bleed every other day if not daily. All upstairs rads getting air, and one downstairs in utility room, same room as boiler and not far from airing cupboard.
No evidence of a leak, used thermal camera and not able to see any leaks. All pipes are copper and are in walls (house built in 1997, so no pipework under floor on ground level) micro bore pipes upstairs, and some downstairs. No wet carpets, or wet walls, Only one small section of pipes buried under concrete which is in conservatory (done over 15 years ago), which I ensured were wrapped around (using an old hose pipe to prevent concrete making contact with copper pipes.
Have had a new boiler (ideal logic H24), new pump (Grunfoss UPS3) and now a new hot water cylinder (Gledhill indirect unvented stainless lite plus) along with new expansion vessel and combination valve, however I’m still getting air in rads. The central heating is fed by an F/E in loft, I have seen it drop water level, by about 10mm height but I cannot be certain if that’s merely expansion and contraction, and/or evaporation related.
British Gas replaced the pump, tried to T the F/E pipes thinking it may be drawing air in, but no joy, now replaced the cylinder thinking maybe that might be the cause, but no joy. I have tried to suggest they do a gas test on the central heating, but seem reluctant… no idea why as that would be my first port of call, but instead they replaced a hot water cylinder. So any thoughts how to figure this issue out? The hot water is mains pressured.
Then now there’s the 2nd issue (caused by this troubleshooting effort by British Gas/Dyno). The new cylinder is made by Gledhill (indirect unvented) and comes with a 19l Zilmet expansion vessel, and a Reliance Combination Valve. All configured and checked to 3bar, and cold mains pressure entering the house is reduced to 3bar to balance the cold and hot supply. When the hot water is used you can hear the water flowing very loudly from around the combination valve, like an aircraft. Also, periodically you hear loud popping noises from the airing cupboard (when the hot water is being used), almost like cylinder is imploding like when a coke can or plastic bottle contracts and expands… is it possible for this to happen on a cylinder, or is the noise possibly from the expansion vessel or combination valve? When it makes a loud pop, it does feel like it’s the cylinder, but I could be wrong, Dyno installed the cylinder and they’re asking Gledhill for support, but I feel that I’m going to get fobbed off, saying it’s normal etc etc. The only reason the cylinder was replaced was because they suspected the air in rads was the cylinder. We had no issues with the old Tribune Premier cylinder, old expansion vessel or the valves. So I have 2 issues now, air in rads, and noises airing cupboard where hot water usage causes unacceptable flow noises and loud popping noises.
#1. Any thoughts how air could be getting into rads? Some of my rads do have white deposits around the blanking and venting plugs.
#2. Any thoughts on the water flow noises and popping noises in the airing cupboard? Is the valve likely to be faulty, or maybe the pipework, and could the cylinder have a dimple inside that is popping in and out as the hot water is being used, or a noises diaphragm in the expansion vessel, or a sticking combination valve?
I have posted a video of water flow noise (might need to increase volume to hear), the initial clicking noise you hear on video is not the loud popping noise, I haven’t been able to get a video of that, just too difficult to be there recording just before it happens).
My knowledge of plumbing is near zero, but I have self learned at lot in the last few weeks! But now I’m at a loss, and feel like that I’m going to get fobbed off by BG/Dyno.
Any suggestions you guys have I’m willing to try….
Thanks!
Thanks!
IMG_3958.MOV37.5 MB
