Discuss Boiler part replacement jobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
larsson67
Just seen a job advertised offering £140 a day to replace a part behind the heat exchanger for a leading boiler manufacturer 3 of these a day , just wondering if anyone on here is doing or has done this or similar work ?
They keep emailing me
3 day induction and should take 3-4 hours per boiler
sounds carp
Not sure what part , it doesn't even say what boiler manufacturers , I'm assuming it involve draining down the boiler to get to the part
If you've got no work (and nothing in the pipeline) £140 a shift is better than loose women and Jeremy f****** Kyle
Use it as a stop gap if you need to, never say never
Imagine if we had to do the natural gas swap over again....with Serco and other similar leeches sucking the t*t
Each boiler takes 3-4 hours (plus travel time?) and you have to do 3 for 140 sheets? That's is proper carp money.
Reply to Boiler part replacement jobs in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
