Discuss Betacom 30 inner cover ceased and will not come off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
manic26
Hi anyone come across such situation? If yes what happened and how did you overcome. Cheers
I would suggest its a melted seal. I've only come across this once and in the end just went round the edge with a Stanley blade. Completely cleaned it up replaced seal and has been ok ever since.
You got it off then? Was the seal melted??
Not off yet but I'll follow your suit once I get my hands on the seal
Just my parts supplier they had them in stock
Reply to Betacom 30 inner cover ceased and will not come off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Hi, I have an old steel water mains pipe (approx 45mm) that I need to connect to a new pehd water mains (25mm). I can't get at it to create a new...
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his...
