L
learnplum
Hi, do most use a hand held device, or a spring, if you are a samson, or a free standing device, like the hilmor one?
Thanks.:tounge_smile:
Discuss Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks guys, can you get a hand held accurate bend?
Or is the free standing floor hilmor more accurate?
Hand held! Good for upper body muscle building!
If you are a bit devoid of muscles it can be hard to bend 22mm in a hand bender though.
I use a old record one that my gf's grandad gave me. But it seems to deform the pipe in the guides a little. Then the pipe is really tough to get out. Only on 22mm though. Anyone know why?
Hi the hand held looks more hard work?
Isn,t it about right tools, pay a bit more, easy life?:tounge_smile:
You starting to feel your age :wink:I would say a hand held device, in the year 2015, is backward?
Too much effort? Too pull a simple bend?
it is not hard to bend 22 mm with a hand held bender. kyle said it before and i will say it again now. simply rest one leg on the floor and use your body weight to operate the other arm as a lever.
if you dont do this you will likely need steroids!
If they're your girlfriends grandads benders they woulda been for 3/4 not 22mm I'd sayI use a old record one that my gf's grandad gave me. But it seems to deform the pipe in the guides a little. Then the pipe is really tough to get out. Only on 22mm though. Anyone know why?
Reply to Bending 22mm pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
