Discuss Baxi 600.............. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
There ok got some good points and bad
Medium boiler for me (the 600)
Got to quote for a mid range combi in a loft
Can't decide if I should try a 600 or stick to a logic
try the 600 mate
As it's an alu hex every year
It's going in a loft, no need for a PRV as it combined
No need for a frost stat & pipe stat as the weather comp sensor protects it
cant run the condy in solvent weld needs to be pushfit
Was thinking about this today.
The condensate adapter on the boiler is to connect onto overflow pipe. This is always solvent weld and not high temp as far as I know?
Yea don't they come with the flexibile tube ?
Reply to Baxi 600.............. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Does anyone know a good, not super expensive, leak detection company in the London area?
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
