P J F PLUMBING
Pump fault flashing. Low pressure / pump the boiler is on 1.5 bar pump shot changed the pump. Three days later pump light flashing. I'm lost ???
Discuss Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
thats not going to help if the port under the small diaphragms blocked or the microswitch/wiring/pcb is not seeing continuity though is itSounds like pump proving fault. Glue a 5p coin to underside of arm or strip valve and change grommet.
no,the op is asking for fault finding adviceIt's my favourite fix. [emoji12] only taking pish. Wasn't it a hall of fame photo?
Reply to Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
