Discuss Bathroom sink help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys
Switched off boiler + water. Somehow almost broke my bum trying to undo the old sink and drilled holes for the new one... I looked at the tap and I was like... ? I'm not used to this connection. Any ideas before I have a breakdown? Thanks :(
Your new tap has half inch connections you’re existing pipes finish in 3/8” swap them for two of these
https://www.NoLinkingToThis/p/compr...MI2eXi68T74gIVLLvtCh0N1wLjEAQYASABEgJ4F_D_BwE
ah man I wish it was something I could do now. No water again -_- why can't Screwfix be open 24/7? I'd go there and grab one.... If somewhere was open I'd bloody buy it :( thanks...
ah man I wish it was something I could do now. No water again -_- why can't Screwfix be open 24/7? I'd go there and grab one.. If somewhere was open I'd bloody buy it :( thanks...
Suzan, if you're going to be tackling more jobs to save having no water, you may want to purchase some stop ends?
E.g.: https://www.NoLinkingToThis/p/pegler-brass-compression-stop-end-15mm/3519g
https://www.NoLinkingToThis/p/pegler-brass-compression-stop-end-22mm/6428g
https://www.NoLinkingToThis/p/jg-speedfit-plastic-push-fit-stop-ends-15mm-2-pack/94176
wrong fittings on the bottom need couplings and not male irons
But I did what everyone said. On the first page told to buy 2 of those adapters... Now people are saying no???? I don't want to go without water again today cos Screwfix are now shut :(
Reply to Bathroom sink help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
