Discuss Bathroom sink help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got 2 for both hot and cold
Change them for these.
to be fair you didnt say you were extending the pipes just the flexis wont fit the old male irons
So weirdly no matter how much we tighten the coupler to the copper pipe it still leaks a bit. The pipes are old and we scrapped paint off with a Stanley. Clean with wire wool stuff. Any ideas? No PTFE used.
Quite possibly he’s over tightened them if he’s used all his strength. These fittings are meant to be just nipped up not strangled to within an inch of their lives.
Try a turn or two of ptfe on the olive
Reply to Bathroom sink help with tap? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
