Discuss Anyone recognise this magnet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
finchy01
Afternoon chaps. I've seen this before but never worked on one (I have spyro in my head) there are no isolation valves on it so I can't see how I can remove and clean it! The guy who put it in left no paperwork so I can't check. I've only used the Worcester and magnacleans before. Any advice would be great as I hate feeling a numpty when I'm at customers houses!
Looks like a magnetic filter that BG used to fit. Not on their current website, but a couple of years ago:
Magnetic System Filters - Heating Accessories - British Gas
I remember there being a bit of a scandal with them because BG charged a lot for them (ca £250) and refused to honour their 'free' servicing deal unless they were fitted. Can't remember exactly.
I imagine, but have never played with that model myself, that the big black saddle is the magnet and can be removed, there's probably a retaining screw to let the magnetic drop downwards. So stop all circulation, drop magnet, wait a few minutes for the sediment to drop into the cone at the bottom. Remove the end cap and cautiously open the ball valve that it screws onto and the sediment will squirt out into the container you're holding. I'd have expected there to be a couple of isolation valves and a bleed valve. If there aren't I guess one needs to be cautious.
I'm sure someone will know exactly how it's done, they were sold pretty hard by BG.
spirotech mb3
Remove mag shield and put tray under or a washing machine hose into a bucket
And open the valve using the cap
1. Turn system off.
2. Pull magnet down slowly and off.
3. Undo cap at base of MB3
4. Fit hose to exposed spigot.
5. Use slot in cap to open valve at base and direct waste water (and muck) into bucket. Half a litre is plenty
6. Close valve.
7. Slide magnet back on.
8. Bring system pressure back to normal if necessary.
9. Issue invoice
It's a Spirotrap MB3, which appears to have been incorrectly installed - or is the pic?
The main part, with the black magnet should be vertical, not horizontal.
This is achieved by undoing the large knurled ring and rotating the body. You may need to undo the two compression joints and rotate the whole unit to the left so it avoids the wall.
I have attached the instructions
  • man_spirotrap_mb3-1.pdf
I know some of the 'main guys have left but that is the response I was hoping for. Top chaps! Many thanks.
Reply to Anyone recognise this magnet? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi all. I hope you are well. Need some advice on this boiler and fault. E229. Went there and condensate was totally blocked so cleaned it and...
I’m finding it hard breaking into the industry. I’m a trainee plumber living in London Hello, I'm a trainee plumber who lives in London who's...
Hi, some advice would be great. I have an Instinct Eco-Mag fitted and it has started to leak from the port that the magnetic tube is removed from...
