Discuss Anyone got / tried one of these? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Also while we're at it has anyone got any tips for removing scale from pipe like you'd get from a leak that went unnoticed for ages before sealing itelf? I find that harder than paint by far.
No. I remember someone posting on here a few years ago about same.
Bet it scores the pipes but no different than using the blunt back edge of a Stanley knife I suppose. Blow lamp if safe does a good job usually to soften the paint and a rub off with steel wool.
If pipes have scale damage from leaks I always just prefer to remove the bit of pipe and replace. But if not possible - like a rad valve pipe going into a solid floor, I just scrape it with back of knife blade and use emery cloth on it. Bad long term leak on copper can cause pin hole leak
That's definitely a plumbers tool box in the video with all that carp in there!
I just use my grips to take the worst of it off then a cleaning strip to finish it off.
That paint looked like it come off far to easy. If I get bored I throw a compression on it.
on another note, I've started to use my vein for cutting awckward pipes. Like retro fitting a Magna clean.
Reply to Anyone got / tried one of these? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I have an issue and hoping someone could shed some light on the problem. We have been getting a smell coming up in the bathroom...
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
Did anyone watch Britain's Got Talent last night? There was a Plumber on from Stockport called Darren who bottled it last year but did his...
Hi Everyone, Does anyone know where to find out what size the O rings are in a Mira 723 service kit as I have one (at the pointy end of the...
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
