Discuss 837 Eco tech plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Douglas
Can anyone tell me how many draw off points a combi can supply? & how to work this out by using volume & flow rates? Cheers!
I assume you are referring to the Vaillant EcoTec Plus 837 ?
Vaillant state 15.2 ltr/min but that can be effected by how good the mains pressure is in your area.
It will probably be easier if you state the type of intended property and number of bathrooms etc then folks can advise you if its suitable or not.
Combi boilers
Yeah it's a vaillant 837 Eco tech plus, is this combi ok to supply 2 bathrooms & a downstairs toilet?
How do you calculate & find out if this boiler can supply these draw off points?
Re: Combi boilers
Connecting to a downstairs toilet, well id consider upping the rate. those suckers after a night on the beer and a kebab on the way home will draw off all the hot in a flash.
now being serious mate yes it will be ok for ur house.
Re: Combi boilers
just fitted one to a 5 bed 2 bath house, all ok.
Reply to 837 Eco tech plus in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few...
