Discuss 50mm Waste pipe hole size in the USA area at PlumbersForums.net
As in you shouldnt attempt to run 50mm pipe through joists?you wonāt do 50mm in joists
I was thinking something like thisAs you say, 1/4D is a recommendation - perhaps you can reinforce the joist in some way in order to compensate?
Or that a 50mm hole is too tight a fit?
If its the latter i was just trying to get a idea of how oversized people usually go to allow for maneuvering the pipe, creating enough fall etc
Reply to 50mm Waste pipe hole size in the USA area at PlumbersForums.net
