Discuss 50mm Waste pipe hole size in the USA area at PlumbersForums.net
What hole size would you recommend drilling for 50mm waste pipe that needs to go through a joist?
Joist is 200 deep so a 55mm hole is already a bit over the recommended size for that joist.
If you're going to go through the joist then it's obvious that the hole has to be bigger than the pipe and that the pipe shouldn't rub (or wrap it in something that will allow it to rub quietly and without abrasion).
As you say, 1/4D is a recommendation - perhaps you can reinforce the joist in some way in order to compensate?
60mm min you won’t do 50mm in joists
As in you shouldnt attempt to run 50mm pipe through joists?
Or that a 50mm hole is too tight a fit?
If its the latter i was just trying to get a idea of how oversized people usually go to allow for maneuvering the pipe, creating enough fall etc
I was thinking something like this
Or possibly glue and screw 18mm ply either side before drilling through the ply and the joist.
Both unless the joists 250mm plus or I joists
Reply to 50mm Waste pipe hole size in the USA area at PlumbersForums.net
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can...
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
Morning all. What size diamond holesaw do you use for drilling the hole in a quartz countertop for a basin waste to go through? I have a house...
Hi, came across this old push fit waste pipe. Stripped out the old shower and it was a 40mm waste pipe siliconed in the fitting. The fittings at...
