Discuss Leaking magnetic filters... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
Has anyone come up with a good way of stopping these weeping when they have been serviced but with no new seal. Too many to carry around a seal for all of them.
I have one to go to today which I have not heard of. It is called instinct eco mag. Cannot get a replacement o'ring in time. Cheera
What one you found leaking as I haven’t seen a leaky pro 2 yet or the old red sticker
Not seen it yet as client called last night.
Sorry to post on this thread. Anyone know if you can get a tee with spigots on both ends to put in here... a slip tee?
Reply to Leaking magnetic filters... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Forgive my ignorance, with this basic question, but I seem to be struggling to both understand, search for, and source, the appropriate washer, o-ring or gland, for this type of tap. Maybe, no one ever replaces this type of washer/component? Background: I discovered a leak in the cupboard from...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my 20-year-old unvented cylinder (an Ariston Classico HE STD 150) 5 days ago and I hadn't noticed that it was leaking. He fixed the leak today but now the...
Hi, as you can see pictured I have a stopcock without a packing gland. Over the past few days my cistern inlet was suffering from an airlock and it was hammering constantly after filling. I turned off this stopcock, drained all the pipes, turned the taps back off and then let the water back...
Hi, some advice would be great. I have an Instinct Eco-Mag fitted and it has started to leak from the port that the magnetic tube is removed from (common issue i believe). I have seen a video on here showing a temporary fix by adding some O-rings. Problem I have is that when the boiler was...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
