Discuss Worcester 28CDi return manifold in the Central Heating Forum area at PlumbersForums.net
No it does not all accessible
Reply to Worcester 28CDi return manifold in the Central Heating Forum area at PlumbersForums.net
Hi Everyone I wasn’t sure whether to post this in here or UFH but hopefully I’m posting this in the correct group. I’m in the throes of a full...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting...
I have a badly blocked feed pipe to kitchen rad, was running very slowly but I’ve made it much worse trying to clear blockage with curtain wire...
M
Hi.I have 6 caste iron rads and want to connect them all the lines are in with the stubs sticking out of the wall. There are two manifolds down...
R
Wb 4000 recently installed, and just balanced the rads with around 16 degree delta across most rads. I'm trying to make sure that the return...
Return temperature
R
