Discuss Where can I get whatever this olive is called? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Just had right mission trying to join on what I think must have been 15mm copper going into a imperial sized compression tee. On the pipe there was an olive that was compressed flat onto the pipe on the end that went into the fitting and raised and flat ended on the other side to seal against the nut which had a large gap around the pipe too large to be grabbed by a standard 15mm olive not matter how tight.
I've seen them before and heard them mentioned on here before but forgotten what I've heard themthey were called. And this was the first time I've really could have done with a new one as I didn't want to use the original one as pipe was a bit worse for wear.
What are these called? Can you buy them? And can they be used to help a 15mm copper pipe seal into an old fitting?
Incidentally no 15mm nut I had would join onto the thread of the old fitting otherwise I'd have just done that.
You are talking about a .'Cone'.
No I do not think you will get one. No the thread will not fit modern nuts. You probably need to re use it if you can or replace the fitting
Thanks, that's a shame. Would be handy for joining onto an old imperial compression fitting with new pipe.
I've noticed places like bes do 'imperial compression' ... Would this just be compression designed to fit well on imperial pipe rather than machined to have threads that would match/fit old imperial fittings?
Actually I think I'm still confused about what I was working wit. I don't think the fitting can have been imperial as my new metric pipe was too loose in it, whereas it should have been really hard to get the pipe in if it was imperial. I guess there were just metic fitting designed to take a coned olive, for whatever reason.
It would be imperial. 1/2" and 15mm Are near as damn it the same. You will find that 1/2" can be a tad tight in 15mm fittings though.
Ca you not replace the whole fitting?
Why is 1/2" tight in 15mm fittings when it is smaller? Is it because even though it's bore is 1/2" the wall was so much thicker then that it actually ends up the same o/d as 15mm or greater? If so that might explain why the speedfit attached to it for 2 years was happy as larry.
Replacing whole fittings means digging into wall.
I've also noticed that plenty of 15mm pipe is a struggle to get into plenty of 15mm fittings anyway these day presumably due to cheaper production.
I had one in the garage pm me your address i will post it to you. Cheers kop
1/2” inside diameter gave (I think, don’t quote me), something like 15.8 mm. outside diameter. There about, roughly.
Reply to Where can I get whatever this olive is called? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe...
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
