Discuss Waste screw not long enough?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Drunkn Munky
I ordered a complete bathroom suite from trueshopping and the waste screw for the bath waste is not long enough to pass through the waste grid, bath and into waste mechanism. Are longer ones available? or can they only be purchased as a kit. I will be calling trueshopping tomorrow but i want to get the bathroom finished asap so if i get get a screw elsewhere then i will.
The cheap wastes that come with baths are rubbish really, I'd go to a plumbers merchant first thing tomorrow and buy a brass one like in the link, or at the very least another cheap waste, the cheap ones are only £2-£3 anyway.
Or you could use a tempory bolt (it will be a metric thread) and get the manufacturer to send you a replacement and just swap them over when it arrives, this will allow you to finish.
Don't forget 'normal' bolts will rust.
Chrome Bath Combined Waste & Overflow Plug & Chain in UK at Discount Prices
Why do bathroom manufacturers always have to supply rubbish wastes in there bathroom kits, at their costs surely it would not be much more to provide decent stuff
I do not do many bathrooms now but when I did, I would quote for bathroom installation and at the end add 'x' for bath, sink wastes and w/c handle, customers always windged and I would say if I can used ones supplied will but if not then that’s the cost, once they arrived showed customer rubbish and supplied mine, same thing with alot of kitchen sinks
Have just experienced the same quality problem with the waste for our own new bathroom basin.
The height adjuster screw at the bottom of the plug is made from ordinary steel and is rusting already.
If you look down the plug-hole, the mechanism is also rusting as it's made from ordinary steel.
Don't these cheap manufacturers know that ordinary steel rusts in water ?
Reply to Waste screw not long enough?? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
  • Locked
Hi all, You guys helped me out a while back with a slow filling cistern, I'm hoping you'll do so again! I'll do my best to explain what's...
20K
  • Locked
I have installed a new en suite, tiles etc and am quite happy, however I am having a problem with the basin. I can’t get it onto the wall...
4K
easyt
E
G
  • Locked
Hello All, I am renovating my bathroom and apart from every other thing that made life difficult I have a leaking back nut on the basin waste. It...
21K
T
  • Locked
Hello! I'm hoping you guys can help with this one as its proving to be a real nightmare for me. I'm trying to change the waste pie...
8K
E
  • Locked
Hi, I'm currently "living" with my decorator/plumber who has been renovating the house. He has just ordered and fitted some new bathroom taps that...
13K
darrenangel
