diy_monkey
Hello!
I'm hoping you guys can help with this one as its proving to be a real nightmare for me.
I'm trying to change the waste pie and overflow on my bath. The bath is about 60 years old, so getting the old system out was difficult to say the least, but I did eventually manage it. Once I fitted the new pipe I found that it isn’t as long as the old one so now does not reach the U bend. See the photo below there's about a 10 mm gap between the two (I put white tape on the end of the waste pipe just to make it clearer in the photo).
The waste pipe goes into the wall behind the bath and is very solidly cemented in so there's no chance of moving it (see second photo).
If I try to screw the U bend onto the waste pipe it goes on crooked and causes massive leakage because the two don’t sit together right.
This is causing me major issues as obviously I can’t use the bath properly at the moment. What to do?
Thanks in advance.
Thanks in advance.
