Discuss Vokera Compact 25he Cuts out on heating? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Kewat66
Hi All,
i have vokera compact 25 that was not working at all. Had a good look at it and it ran with the cover off but not on. Diagnosed it as a Venturi. Replaced this and thought problem solved. Now the boiler works great on DHW but lights for about 10 seconds, then stops for 3 minutes, then lights & so on.
the pump seems to be working as I have checked this with magnetic wheel so it doesn't look like the pump.
temp remains the same on flow and return though?
vokera technical said there is a blockage on the system but boiler looks fine? From cold the boiler runs for about 3-5 mins then goes back into this cycle?
Surely if there was a blockage it wouldn't run from cold for a few minutes? Can the pump look as if it is running but actually not be?
any ideas on what I am missing?
thanks
kewat66
Reply to Vokera Compact 25he Cuts out on heating? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
