Discuss Side Entry Ball Valves (2 of 2) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks first of all,
Basically I will need to install wherever I go the extended arm version to prevent back flow and also too installing a double check valve ?
The type you will need to install is known as a part 2 valve. Looks like this
Or also like this
You dont need to also fit a dcv if using this valve.
Yes also correct as they can and do back syphon.
Why the extended arm? Are the cisterns a special shape or size?
yes plastic duo shells wider than normal so a normal part 2 the ball would be where the hole for the flush is
Alright, talked enough ...
For me is clear now I will use part 2 including a double check valve instead isolation valve and I am on the safe side. That's all I wanted to know cheers all for the massive help
But it's better to use a ISO valve before double check in case the double check is gone
Might have to resort to a plastic part 2.
was thinking that can you get a decent one because the ones ive seen are crud but then my thinking is that can still back up water level will have to be a bit higher but could still happen
the position of where the water exits the valve...
Even if they have a piped overflow set too high the water level would normally spill over the syphon in to the pan before it reached the outlet on a part 2.
I am so happy we do not have such issues in Germany we hardly have tanks in the loft ... Gravity dies out there ... Most of the time we have geberit frames for toilets ...
You don't need a dcv if using a part 2
Reply to Side Entry Ball Valves (2 of 2) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have 3 port value for HW & CH. Loft extension added many years ago so they added a T to go upstairs, only 2 rads up but 11 downstairs...
Hi! Our main stopcock is weeping. I phoned the water company, first-person thought it was their problem as it was on the 'outside' of the water...
I have read a few threads including one by Debbie Stano that were similar to my issue but that thread stopped a while back without any resolution...
I am SO fed up with failing side-entry valves on toilet cisterns and water tanks. They've all been engineered down to something as flimsy as a...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
