Discuss Quick question... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gassafe
Gotta quote replacement trvs... like for like, all currently on microbore plastic with those collapsible internal brass reducers which I don't normally rate!
Is it okay to re-use the these fittings or isn't that asking for trouble... don't want to have to add couplers on all of them as it would look a mess!
If it's the one piece brass ones, in my opinion I don't rate these and it is the chance you take. I've had these leak from new.
The 3 piece ones with the olive in the middle are as good as you get for internal reducers. If it's them, then jet blue it as you go, should be fine.
if one piece i wouldnt use them again i have always found them ok always wrapped pt. around the gap so when it splits as you tighten its helps the seal. i would fit new olive/ reducers
One of these good ideas on paper.
But Fails in practice.
Ptfe and they'll be OK
If they're 15 x 10 what about a Push fit spigot reducer, it may give you some length without adding a coupler.
Can't see any 15 x 8 tho'
It's the drayton 1 piece collapsible ones onto 8mm plastic I believe, think I'm gonna have to brace it but there's about 15 to do :(
I tend to take some yorkshire reducers ( they are longer) and cut the microbore, solder on and replace with a 15mm valve.
You sure it's 8mm plastic and not 10mm? Don't think I've ever seen 8mm plastic, is that a thing?
I hate those collapsable reducers bloomin horrible idea, I'd be 'too busy' unless there's scope to redo all the pipe ends, if the pipes come up from under the floor you're laughing.
I normally do that but less options on plastic... pretty sure it's 8mm grey plastic
Reply to Quick question... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
Morning all, as always can never find an exact existing thread / discussion where I don't feel like I'm making one too many assumptions. Can I...
We currently have the ground floor wet UFH and upstairs rads running from an unvented condensing boiler. Any advice/experience on the following...
Hi all, had some great advice on this forum and need a bit more... I've used this reducer (pictured) to step down a 22mm lead loc coupler to 15mm...
3K
I'm sure this is an old question but here goes. I'm looking for some advice regarding switching from a conventional boiler to a combi. I moved...
