Discuss Purging larger installations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pssst
Im just trying to dig up a reference to this....now due to the small volumes of typical domestic installations we would usually purge by relighting an appliance or using an appropriate fitting.
Obviously UP1/1A are the relevant docs for larger installations but is there actual quoted procedure which states what can and cannot be purged into an internal space . In short what is the cut off point by which you MUST use a purge hose and vent it direct to outside?
Anything over 0.035m3.
Can you quote a ref please?? I think back in the day a rough rule of thumb was that if the purge vol was 10% or less than the internal space then let it blow..whooshh..
Ige/up/1b for smaller domestic
............/1a as above
Yes i have copies of both UP1B and UP1A..can you quote the relevant section/paragraph no please?
No but if you read them cover to cover you will find what you need.
Reply to Purging larger installations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Greetings, esteemed community members, I find myself in possession of a remote and highly inaccessible plot of land, devoid of any utilities. On...
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in...
2K
Hi, I'm wondering if anyone can help with a query. We have recently had a new kitchen installed and are arranging for our freestanding gas cooker...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
https://www.telegraph.co.uk/news/2023/05/12/the-heat-pump-farce-has-finally-been-exposed/?li_source=LI&li_medium=liftigniter-rhr I realise not...
2K
