Discuss Gas cooker installation in the Gas Engineers Forum area at PlumbersForums.net
Hi, I'm wondering if anyone can help with a query.
We have recently had a new kitchen installed and are arranging for our freestanding gas cooker to be fitted (Leisure Gourmet Cooker 60cm)
I have read that there needs to be a 20mm gap between the sides of the cooker to meet the Gas Safe guidelines - or default to the manufacturer instructions. I'm concerned as I don't know if there is quite the required space between the sides of the cooker.
The installation manual for this model does not specify anything re a 20mm gap. It only specifies the height clearance 'hot zone' which we are within the limit of. It states that the cooker 'can be used with cabinets on either side' and that 'any kitchen furniture next to the appliance must be heat resistant (100 degrees).'
My question is, will the 20mm gap rule still apply in this case if the installation instructions do not specify? I want to ensure this is clear before calling out the installer.
Any comments very welcome!
If you have the manufacturers instructions, go off their recommendations and instruction.
The guidelines are there in addition and in case the manufacturers instructions are not available.
Can you prove the units either side will withstand 100 C? (written proof or demonstrated).
Reply to Gas cooker installation in the Gas Engineers Forum area at PlumbersForums.net
Hi there, Big gas noob here. We got a gas cooker installed a few days ago, and the gas cooker is now sitting quite far away from the wall (3cm which sounds like not much but throws the balance off of the kitchen), which means there's a large gap now between the cooker and the wall, but it now...
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer & Vaillant engineer say one thing, whilst the SGN engineer says another. I do not know how to proceed and would value some informed advice. The rock...
1K
Hi, We're changing our old electric range cooker for (hopefully) a dual fuel (electric oven/gas hob) range cooker. We have a pantry room directly behind the cooker - just wondering if there's any point in us exploring the possibility of installing gas bottles in the pantry for the hob, or if...
2K
We are renting currently boiler in active for more than 3 weeks no despite landlord having 6 engineer visits It just stopped working had a fix lasted two weeks then off again. so know getting onto a 5 week issue. No current gas safe certificate in place boiler installed to low with not a enough...
We are getting a new gas cooker installed on Sunday. The existing one is over 25 years old, as such I'm having to do some prep to make sure it's ok to install (remove wallpaper from the hot zone for one). In looking behind the existing cooker I have noticed there appears to be a twin and earth...
4K
