C
chrisg10
As above, my boiler keeps producing this fault every now and then. Any one got any fixes for it?
Discuss Potterton Promax Combi HE Plus, E133 Fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
its e160 i got hat wrong in the other thread dohE133 - The dreaded fan fault! ... Intermitent could be gas pressure, ignition or flame detection, condensate blocked .... etc.
All gas related bar the condensate ChrisG10. Check its route is clear I'd say otherwise get a GS engineer in!
E133, If your boiler is over 2 years old, Chances are it will require a new upgraded part (720222***) to be fitted. A GSE should be sought (Easy Fix)
dont think the store is the same as a normal promax combi e160 on the promax/heatmax/duotec/platinum/gold combis is fan failure and it wont be intermittent like your fault it will be fully deadchris
did your boiler have the e160 fault or somehing different please?
nick
Yes but I do find it difficult to see the sparkSo you have a spark but it won't light?
take them out and see if they sparkYes but I do find it difficult to see the spark
Can you feel if the spark jumps?If I'm getting a spark within the boiler wouldn't that mean it's ok or do they need to give a certain current to ignite.
Everything else seems to run fine but no gas for ignition.
Did you try adjusting the old gas valve? If someone had been out before you and cranked the throttle down, or even up too much, that may have caused the problem.
Reply to Potterton Promax Combi HE Plus, E133 Fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
