Discuss Input would be appreciated in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Toxic Ted
I need to fit a combi to my own house, which needs to only last a couple of years but i dont want to fit carp. I normally fit veissmann but as i will be installing unvented and solar this unit will be removed. I have read that alot of you are fitting baxi's and would appreciate your recommendations as i havn't touched one of them since they caused me problems a few years ago....thanks in advance chaps.
LOVE a axis have done 9 since mid November. But if you are pulling it out after 2 years get the main version speak to Ray he's the man to hook you up.
Why not choose a good combi now, and temporarily use it for all hot water.
When you put your solar and unvented in, switch the combi so that it only supplies the kitchen sink, but otherwise operates as a system boiler, driving the heating and backing up the solar.
Saves throwing away a perfectly good two year old boiler.
Go with an ideal logic. Ray might have one with a scratch on the case that he'll practically give away!
Absolutely hate working on my own boiler changing diverter valves and plate HE.......I have just got the job of doing just that to my cousins house though.
Go for a heatline Monza, it's a bargain £500 ish boiler but I've still never had a call back to one and I've fitted 5 over the last 3 years :p
Are they still listing a premium rate number for their tech support Ian?
We used to sell a lot of Heatline Capriz (which I think is the same as the Monza) but we gave up on them when they bought out the 0900 number.
Reply to Input would be appreciated in the Plumbing Jobs | The Job-board area at PlumbersForums.net
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
Hi, I have a PRV located in a heated plant room that is between a pair of stop cocks. It was installed to keep pressure under 3 Bar a couple of...
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the...
I have had a copper pipe shark bite fitting fail dramatically resulting in lots of damage. This was in a ceiling application and done 11 years...
