Discuss Safety of shark bite type fittings in walls/ceilings in the DIY Plumbing Forum area at PlumbersForums.net
I have had a copper pipe shark bite fitting fail dramatically resulting in lots of damage. This was in a ceiling application and done 11 years ago. Do I need to remove the 2 other fittings that presently look ok? For some reason I can not up load picture , but fitting separated about 1 inch with ring of teeth hanging loose . I read something about electrolysis , etc . There are forums saying these fittings should only be short term and not used where hidden (like ceilings) while my local plumber says they are fine. Appreciate input
I think most would say they'd avoid hidding and certainly not burying any push fit fittings but somtimes you have no choice. I'd take it up with Sharkbite...
Reply to Safety of shark bite type fittings in walls/ceilings in the DIY Plumbing Forum area at PlumbersForums.net
