Discuss immersion cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
ianjohn
Bit of a problem. fitted a new immersion tank and after a bit of a struggle and one or two drips ( sorted now ), I am not getting any hot water, flow pipe on the coil hot but return cold, im thinking an air lock but there is no vent, how best to get rid of airlock. Advice greatly appreciated
is there anything I can do without fitting anything, cause ive had a gutful of it and I don't really want to drain down anything
ok i'll try that thanks. of course this is just my guess about air lock, does this seem the most likely problem
also I read something about putting your hand over a tap spout and then turning on hot tap then cold tap. bit confused about this and how it works
Are you not getting hot water to your rads or to your hot/cold water taps?
Are you sure there is no vent? Any thing that looks like this?
Have you plumbed it in correctly ? Did you indentify each connection before you started ?
not getting hot water to my taps.Rads hot. definitely no vent anywhere.
ok but on his vid no water is coming out of the hot tap to start with, whereas im getting water but its cold.
Then you need to vent the system, post #4, fitting a vent would make life easier in the future
Reply to immersion cylinder in the Plumbing Jobs | The Job-board area at PlumbersForums.net
